tranny temp guage?
Old Apr 2, 2003 | 09:48 PM
Kandied91z's Avatar
tranny temp guage?
i notice alot of people running these.
with the increase power i'm running now i think it might be a good idea to have something like this. is there anywhere i can go to get a general idea of why i'd want one and the best way to go about it?
Old Apr 3, 2003 | 09:14 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
not sure but these guys sell them.www.700raptor.com
Old Apr 4, 2003 | 05:05 PM
formul8!!'s Avatar
Car: 2004 GTO
If you are running a smaller diameter than stock torque converter, then I recommend installing one. Keep an eye on the temps when racing or on the highway to make sure they do not go too high, risking blowing up the tranny.
Old Apr 5, 2003 | 01:41 AM
Kandied91z's Avatar
i have a 2400 vigilante...........
i figured it would be good to have for precaution more than anything else.
Old Apr 6, 2003 | 06:09 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
I race mine every weekend, so I wanted it to keep an eye on my tranny temp. (anything over 150 cuts their life in half) and I needed to fill a hole in the new dash I installed. I ran it last year off a brass T and the gauge never moved-same went for a few other guys I raced with that went this route. Then I talked with the guys that had the deep aluminum pans that were thick enough to drill/tap for the sending unit and their gauges all worked correctly. With their 8" race convertors they were a little over 200 degrees at the end of the 1/4mi. Right now I'm having a guy in a near buy town mill me a new tranny pan for my TH350 so I can install it the right way for direct pan temps.
Old Apr 6, 2003 | 06:11 PM
Kandied91z's Avatar
makes sense..........thanks.
Old Apr 6, 2003 | 09:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't need a deep pan to put a sender in the pan. I found a spot in the side of the apn where the sender wouldn't interfere with the valve body, drilled a hole and welded a weld nut inside.
sheachopper
Jul 31, 2019 11:27 AM
bjpotter
Oct 4, 2015 07:48 PM
