Can someone look at this side axle?
Old Apr 10, 2003 | 08:38 PM
87ROCZ's Avatar
Car: 1987 Camaro IROC-Z
Engine: L98 bored .40 (357 ci)
Transmission: Race Ready 700R4
Axle/Gears: 9 bolt 3.70 posi
I know that there is nothing like looking at something in real life but seeing that I have never seen one of these 9 bolt side axles out of a axle tube I thought I would run it past you guys...
I have no reason to doubt the seller (as his feedback is exceptional)... just trying to get a set of eyes to have a look at this axle to see if there is anything that "jumps" out at the them.. I don't expect there to be anything but anyway... here is the pic...it came out of an 89 IROC , daily driver, 2.77 B/W posi, disc, rear end... exactly what I need to fix my bent drivers side axle...
Old Apr 11, 2003 | 10:28 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Looks fine in the picture. Just make sure it's from the same side.
Miles
Diff Solutions
www.9bolt.com
Old Apr 11, 2003 | 11:03 AM
87ROCZ's Avatar
Thanks Miles
Miles
Diff Solutions
www.9bolt.com
Did all of the side axles for the 9 bolts have the same spline count? Someone on another board said that I would have to make sure I counted the splines as it could be a 26 or 28 spline side axle..
I thought that all of the 9 bolt side axles were 28 splines and the 10 bolts were 26.....???
And yes the one in the picture is the one I need... the shorter drivers side axle!
Old Apr 11, 2003 | 12:54 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
THe 10-bolts have 2 different splines, depending on year model. All of the 9-bolts have the same so it really doesn't much matter what it is. That's definitely not a 10-bolt axle, looks alot like a 9-bolt one.
Old Apr 12, 2003 | 03:31 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
as mentioned before, just make sure is the correct side. that is a 9 bolt axle.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
TheExaminer
Sep 6, 2015 11:40 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
