T-5 To 700r4
Car: 85 Z
Engine: 383
T-5 To 700r4
I'm thinking about putting a 700r4 out of a 91 firebird in my 85z. Was woundering if there was anything that I would need to look out for?. If I do this he want's to put my t-5 in his car. Will I be able to swap out the speedo gears from my t-5 to the 700? and the 700 to the t-5 Mine is cable driven his is not. I also need to know of a good TV cable mount for my Edelbrock carb and intake. Any ideas on this stuff would be great!....THANKS!
Also could i use the auto shifter (Not the Plate) in my camaro?
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
I'll offer you my Built T-350 with shift kit for your t-5 and everything with it!
Also a 91 is Electronic Speedo...As you car is mechanical...My T-350 is also mechanical...
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Mounting the shifter is going to be interesting.
(There is a big hole in the floor where the floor auto shifter goes...)
Manual or Auto is a personal preference thing man, it's really up to you, you have to drive it.
(There is a big hole in the floor where the floor auto shifter goes...)Manual or Auto is a personal preference thing man, it's really up to you, you have to drive it.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
