700R4 probs, bubbles in fluid, slipping
Old Apr 26, 2003 | 05:15 PM
lavamadness's Avatar
Car: 1989 Formula 350
Engine: 5.7L (L98)
On my way home today my tranny started slipping. With the car in O, it would start slipping after around 50km/3500rpms. I was able to drive home in second gear.
The fluid was a light red color, but had bubbles in it. It didn't smell burnt at all. I've done a search, and it seems overfilling will cause the bubbles, but it's been 2 months since the filter was changed, and this is the first sign of any problems.
I'll likely take it to GM early next week, but I was wondering if anyone had any ideas what my problem might be. An easy solution would be nice, but I'm more interested in just knowing some possibilities before I walk in to the shop.
Thanks for any help.
Old Apr 26, 2003 | 09:57 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
sounds liek low fluid level totally
check fluid when hot and idling, make sure is up to full line at top of crosshatched area of the stick, dont check it when its cold
Old Apr 28, 2003 | 01:02 PM
Engine: 5.7L (L98)
Does the fluid level get lower when it's hot? I was in a rush last night, so I just checked the fluid level cold really quick, but it was way past the full mark.
Old Apr 28, 2003 | 03:13 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
It will rise when it gets hot, due to expansion. The engine needs to running, level, hot, & in Park for the reading to be accurate.
Old Apr 28, 2003 | 03:16 PM
91Z28-350's Avatar
I'd change the fluid again, and this time, set the level properly. I had a similar problem once, 2 months, noticed slipping, fluid too high. After that, all down hill and then 3rd went shortly. I'm not saying the fluid is the problem, just that it exacerbated the deteriorating tranny.
You're probably looking at a rebuild within 4-6 months.
Old Apr 28, 2003 | 06:07 PM
Engine: 5.7L (L98)
Thanks for the info! I think I'm going to make an appointment with GM to verify. If it ends up needing to be rebuilt in the near future, I guess it's a good time to consider a T-56 swap.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
6998poncho
Sep 25, 2015 02:56 PM
