t-56 converters and dual cats
Hi guys,
For those that did the t-56 conversions with dual cats, what did you use for the cat bracket? My cats are basically hanging there right now, and I'm not sure how to get a brace installed.
Thanks,
Thanks,
Car: Faster
Engine: Than
Transmission: You!
I completely got rid of the WHOLE exhaust system from smog pump to air-tubes and cats to the exhaust tips! Do yourself a favor and switch to a single cat setup. You will save weight and you'll get a few ponies from it. I didn't want to try to hang the stock stuff with the T-56, a custom bracket will have to made and if I had to keep the stock exhaust, I would sub that job to a qualified exhaust shop.
Hmm, as I had just replaced my cats with dual cats I'd rather not spend the $$$ for a single 3 inch cat. Oh well, may be off to the muffler shop soon.
To clarify, a single cat does not require a bracket? I've never had a camaro with a single cat, so I do not know for sure.
Thanks,
Thanks,
Car: Faster
Engine: Than
Transmission: You!
I dont have any brackets on mine. The headers are bolted to the heads, the y-pipe bolts to the headers, behind the y-pipe is where the cat is welded, after that weld there is a 3 in, collector flange, this is where the over the axle pipe is connected, and finally I have a hanger on each side of the muffler holding it in place.
So no, the cat just needs to be welded in if you are building an exhaust similar to mine.
Hotrodboba400
Dec 10, 2019 07:07 PM
tonys91rs
Oct 10, 2015 03:31 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
