84 z t5
Old May 1, 2003 | 01:12 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
84 z t5
on my 84 l69 ho t5 it grinds in 3rd gear where is the plug located and wat type of gear oil should i put in
Old May 1, 2003 | 11:15 PM
Uncle Skeletor's Avatar
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Plug is on the passenger side, about in the middle of the transmission case. Usually they run Dexron II ATF, but I use 50 weight synthetic gear oil and have no problems. Pull the plug, you should be able to identify what's in there by smell/consistency. Just for reference (I'm sure you already know) the oil should be level with the fill plug hole.
