can u make an open diff a posi?
Old May 5, 2003 | 02:49 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey i have been hearing that theres a kit for like 150 dollars that lets u convert ur open diff to a posi is this true?will i be able to convert my stock 10 bolt of my 85 camaro z28 to a posi with buying a whole posi rear end?
Old May 5, 2003 | 03:20 PM
MikeS's Avatar
true 'nuff
Old May 5, 2003 | 03:34 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, if you get the correct parts and have compatible axle shafts.
Old May 5, 2003 | 03:42 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
You take out the open diff carrier, remove the ring gear from it, put the ring gear on the posi carrier, and install the posi carrier into your rear end.
There is no "kit". It will cost a great deal more than that for a 85.
In addition to the normal clutch-type posi units, you could also get a "mini-spool" (very bad for street use, turns your car into an unguided missile on wet pavement) or a Powertrax Locker.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
