Removing Clutch Fork/Bellhousing
Old May 6, 2003 | 10:46 AM
pauldaniel26's Avatar
Car: 1986 IROC-Z28
Engine: 355 in the works...
Alright, I need to pull my trans to put in a new clutch and rear main seal. So far I've taken off the torque arm, driveshaft and pulled out the trans. All thats left is the bellhousing, clutch cable and slave cylinder. How do I go about removing these?
Old May 7, 2003 | 02:04 PM
PhilM's Avatar
Car: Accepting applications...
unbolt the bellhousing from the block and pull it down. clutch fork will come out with it. just unhook the bracket that holds the slave cylinder. you shouldn't need to remove any type of "clutch cable" since it is a hydraulic clutch. make sure you unbolted the dust cover off from the front of the bellhousing too.
jtwoods4
Sep 3, 2015 05:39 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
