85mph speedo and 145mph speedo swap?
Old May 7, 2003 | 08:06 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Ive got an 86 IROC gauge cluster but it has the 85 mph gauge. Can I just undo the srews holding the speedo gauge and swap mine out? will work and read the correct mph?
Also why did the IROC's come with a 85 speedo gauge cluster?
Old May 7, 2003 | 10:10 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Just swap it in! I did mine afew years ago, and it works great! I even took the speedo apart and switched the odometer reel between the 2 to keep my mileage correct. Now I just want to get a chance to see how far I can get that needle to go! Without the trans going into 4th gear at heavy throttle, I've been lettin off around 110! Not to mention that it's not exactly safe to go that fast on public roads!
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
ChevyZ71
Aug 13, 2015 07:30 AM
