Help!!! Swapping Rear Gears
Old May 25, 2003 | 05:25 PM
86TransAMsbc305's Avatar
Car: 1986 Pontiac Trans Am
Engine: LG4 305
Could someone give me instructions on how to take a 3.42 ring, pinion, and carrier out of a 7.5 gm 10-bolt rear end....or would it be easier to swap the whole rear end? It came out of a 83 S-10, and it would be going in a 86 Trans Am.
Old May 25, 2003 | 05:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I would reccomend getting a service manual. It would be to time consuming for somebody to sit and type the whole procedure step by step.
One thing to note, you'll have to take a backlash measurement and a Pattern check of the old rear before taking it apart. you will need to duplicate the pattern and backlash EXACTLY if you don't want them to whine. I would also reccomend new bearings.
Old May 25, 2003 | 05:35 PM
Engine: LG4 305
What do you mean by backlashing and pattern checking?....I don't know what that means.
Old May 25, 2003 | 05:41 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Maybe its not such a good idea that you do this on your own...
But anyway, here is a quick rundown of the things needed to put a rearend together, you'll see the pattern check and measuring backlash. You'll have to do these two things to the S-10's rear before taking it apart.
http://sethirdgen.org/10bolt2.htm
Old May 25, 2003 | 06:13 PM
jeffsbluez's Avatar
Car: 91 z28
remove all bolts and remove carrier. Its out now take it to a pro. Its too much for you to handle. It takes lots of experience to set a rear up correctly.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
