kickdown cable on a th350 changeover
Old May 26, 2003 | 08:35 AM
ima_20_phan's Avatar
this is for anyone who is swapping a 700r for a 350turbo. you can modify your 700r cable to work on your 350. its not hard to do and it works perfect. i just did it to mine yesterday and although i'm having problems with my trans leaking , the trans shifts fine and the kickdown i made works perfect. i anyonewould like to know how to do this modification, just let me know and i'll provide you with step by step instructions.
Old May 26, 2003 | 11:14 AM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Is modification needed because they are different lengths?
I just swapped a 700r4 for another 700r4 but for some reason the new TV cable does not reach, it is a few inches too short, and I am getting very, very frustrated at this point, to the point of throwing things, so if you can give me some insight on how to just make it freaking work I'd be much obliged, as I really don't feel like changing the cable or dropping the pan and draining the fluid I just put in, or having to lower the tranny any or.....
It's not caught on anything and I can't give it any more of a direct route.... I'm confused.
Old May 26, 2003 | 03:20 PM
FyreLance's Avatar
ttt
Old May 26, 2003 | 06:02 PM
ericmac450's Avatar
Car: 1999 Camaro Z28
yeah man, please if you don't mind, type any instructions to make it work...also if you ran into any problems with the swap...I'm looking at doing this in a month.
Old May 26, 2003 | 09:16 PM
i would not want to give you advice on a 700r to 700r swap . i'm really not too sure why your cable would be short ,unless one of your trans came from a v-6. and if that is the case , one of the cables you have should fit.i'm sorry , but i'm lost on this , never heard of it.
Old May 26, 2003 | 09:20 PM
about swapping cables
i promise you , i will post the instructions for the swap tomorrow. i am a wrecker driver and just got paged out. oh well, it is memorial day weekend. i 'll put it out tomorrow!!!
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
