P'eeed Off!
Old Jun 6, 2003 | 04:50 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
P'eeed Off!
OK... Enough is enough!!!
Enough transmission crap!
I get the damn RS tranny built, now the GTP tranny takes a dump!
I guess I'll be rebuilding this one too!
Another $1000+ I have to spend!
AAAAAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHH!
Old Jun 6, 2003 | 06:15 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The GTP tranny isnt still under warranty?
Old Jun 6, 2003 | 06:42 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Being a 1998, it went out of warranty back in 2001.
What is wrong with it? I work on 4T65-E transmissions regularly. Does it slip some, or does it flat out not move?
Old Jun 7, 2003 | 11:24 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Sometimes it acts like Im neutral dropping it. You know... Reeevvvvv... bang! Fluid level is OK and is still red. Someone told me it might be the converter. Hey GMTech, whats the stall speed of the converter supposed to be? Scott at Art Carr says 1800. This car will stall (hold brakes, gas to the floor) at 3000.
BTW... No codes!
Old Jun 8, 2003 | 09:28 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sounds like it needs a Pressure Control Solenoid. I have done TONS of these. The part itself is cheap (Approx $50 from dealer), its the installation that can be a PITA. The Solenoid used to be $300+, but GM was replaceing so many of them under warranty, I guess they felt they were ripping themselves off!
Old Jun 8, 2003 | 12:07 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Also... when accelerating though say 2nd gear, the tranny makes this awwful growling moaning sound. I was thinking maybe a bushing/bearing could be shot also. Plus, I think I damaged something internally when we had the snow storm here earlier this year. I am guilty of "rocking the car back and forth". What do you think I should do? Should I go ahead and try to rebuild it myself? Its been a while since I've rebuilt an automatic...
MMroc86
Feb 6, 2014 11:48 AM
Rockyd
Sep 25, 2013 09:58 PM
einarak
May 4, 2010 03:11 PM
