built 700r4
Old Jun 7, 2003 | 05:31 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
built 700r4
Im currently running a setup with my camaro that makes 400 hp, Im using a stock rebuild 700r4 with about 3000 miles on it right now. Im wondering what I can do to the 700r4 to make it handle the power its making now, and an occasional shot of nitrous. I just bought a vigilante 9 inch converter for it. Looking for suggestions for manual valvebodys, and that sort also, cause the trans shifts waaaay too weak, especially when I shift it myself.
Old Jun 8, 2003 | 09:34 PM
25thanniversZ's Avatar
even with a build its probably not gonna last.......yes there are some out there that do without any probs , but there slim pickins.... do you have one of the few?? better off with a th350 or th 400....chance it with a rebuild , heel you might get really lucky, but either way me as a tranny mech says good luck
Old Jun 9, 2003 | 12:02 AM
25THRSS's Avatar
The 700r4 can handle that easily. Check out probuilt's website. Thats the tranny to get right there.
Old Jun 9, 2003 | 12:23 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
thanks, Id get a th350, cause I could get a real strong one for dirt cheap but, I really really want my overdrive. Mostly cause of my 4.10 gears. Plus I still drive the car alot. Ill have to take a look at those trans and see what I can work with at probuilts
Old Jun 9, 2003 | 04:23 AM
Pro Built Automatics's Avatar
Use the Modified Trans-Go Performance Shift kit, both boost valves, and Corvette servo. This will give you the best chance on your transmission to hold up to the current horsepower. Let me know?
Old Jun 9, 2003 | 07:05 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
wheres the best place to get the corvette servo and the transgo
Old Jun 9, 2003 | 07:25 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
www.pro-built.net
Old Jun 9, 2003 | 10:35 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Thank you sir, what does the corvette servo do?
Old Jun 10, 2003 | 04:48 AM
Firms up 2nd & 3rd gear.
Old Jun 10, 2003 | 09:23 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
me agrees too, though i aint nowheres near A-rate yet
Old Jun 10, 2003 | 10:45 PM
90formula5.7's Avatar
re
if your gonna make over 400 horse power i suggest a kevlar band , harded input shaft ,heavy duty sunshield and step up the pump to a thirteen vane setup like the new 4l60e's and a heavy pump slide spring, from sonnex. also add more clutches in in your 3/4 clutch pack some can get as many as nine in them but i only could get eight in mine my steels were to thick..
Old Jun 11, 2003 | 03:19 AM
Do not use a "kevlar" band, use the Borg Warner Hi-Energy 2-4 band. They last longer and give a better quality shift. A stock input shaft works just fine as long as you run a 9.5" or 10" torque converter. 13 vane pumps do nothing, except take away oil volume & they cost more. Use the Trans-Go steel chrome rings & pump slide spring. They offer 2 different type of slide springs, one for above 5,500 rpm WOT shift points, and the other for below 5,500 rpm WOT shift points. Depending on what type of driving you do, you can run 7, 8, or 9 Borg Warner Hi-Energy clutches in the 3-4 pack. There are a lot more modifications that can be done to make this transmission last. If you need more reasons as to not using some of the above mentioned items, there are more.
Old Jun 11, 2003 | 03:32 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Im going to go with the transgo shift package and the corvette servo, I'll take your word on the stock input shaft, especially since my converter is a 9 inch. Would a manual valvebody or a reverse manual full patern valvebody junk this trans quicker, because when I race the car I prefer to shift it myself since the trans shifts out way too quick.
Old Jun 11, 2003 | 10:46 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Umm...Yeah...what Pro-built said
Any wonder why I bought one from him instead of rebuilding my own?
Old Jun 11, 2003 | 10:49 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Smart move. I did the same. Best thing I've every done for my car.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
89newfun
Sep 16, 2015 09:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
