Gaskets wont seal
Old Jun 8, 2003 | 01:01 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Gaskets wont seal
Well I am on my third gasket. Last night I finished my trans cooler install and put the fluid in, but my batt was dead so I put it on the charger overnight. When I went out there tonight there was a huge pool of trans fluid on the ground.
I am on my 3rd cork gasket and I used RTV sealant on it too. It is leaking from the same place (front passenger side) But the pan and trans look fine at that point. Should I try a rubber one to see if that will seal it better?
Old Jun 8, 2003 | 07:17 AM
ede's Avatar
ede
try hammering the dimples flat around the bolt holes in the pan. you shouldn't need any sealer on the machined surface, i'd use a thin coating of rtv on the pan. don't over tighten either, it'll split the gasket.
Old Jun 8, 2003 | 07:23 AM
ctandc's Avatar
Yup, that's good advice. If it's leaking and you haven't even started it yet, you've probably got a spot on the tranny pan that's warped.
Take the pan off and lay a straight-edge ( ruler etc ) on each side and look for a gap.
Straighten it up like suggested. As for the gaskets, I always like the rubber gasket better. If I remember correctly, most parts stores sell a rubber pan gasket seperately from the filter kit. Use enough RTV to hold the gasket in place while bolting it up. I normally just put some on my finger and spread it around between each bolt hole, making sure not to put too much on that when tightened the RTV won't go into the pan.
Also make sure you're not overtightening the pan bolts. It doesn't take much at all to get 'em tight.
HTH
Old Jun 8, 2003 | 11:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Make sure it's really the pan that's leaking, and not the fill tube (right immediately above the front right corner of the pan)
sheachopper
Jul 31, 2019 11:27 AM
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
Dragonsys
Sep 25, 2015 03:51 PM
