need flywheel help quick!!
Old Jun 16, 2003 | 05:09 PM
pskel350's Avatar
I have a 1974 350 block in my car (2 piece rear main seal). i am in the process of changing my 700R4 to a 5 speed.
i have an old 1 piece flywheel laying around, i know i cant use it, but why is the flexplate that came off my engine, and the 1 piece RMS flywheel such different sizes? (see pic)
do i have to get a different starter?
will the new 2 piece RMS flywheel be the same size as the flexplate i just took off my engine?
Old Jun 16, 2003 | 05:11 PM
pskel350's Avatar
Old Jun 16, 2003 | 09:47 PM
Odyssey's Avatar
That's beacause the flywheel is a 12 inch flywheel (actually 11. something) and the flexplate on your motor was 14 inch. You cannot use a 14 inch flexplate on your motor, so your best best is to get a flywheel from an 83-86 305 Camaro motor. Or in other words you will need a two piece rear seal 12 inch flywheel.
Old Jun 17, 2003 | 03:00 PM
pskel350's Avatar
will my starter still fit?
Old Jun 19, 2003 | 10:32 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
size difference is as stated above, autos can use the big flexplate (168tooth/14in dia)
the t5 bell housing, will not clear the large diameter so you must use the small dia, 12 3/4in, 153tooth flywheel.
as a consequence of the size difference your existing starter will not work, and you'll need to get one for an f-body with a 5 spd
since your motor is a 2 piece rear seal, you would need the small flywheel to be for the 2 piece, finding one in a junkyard could be time consuming and difficult, at least for me it was so i wound up going to this website,
www.car-part.com
search for a vehicle that would use the flywheel you need, such as an 83-86 camaro/firebird. the site automatically cross references other vehicles, and gives a listing, the you contact the business that has it. wonderful website, more or less a giant classified add, for thousands of junkyards accross the country
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
