Transmission Diagnosis
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I'm having a problem with my TA and I need some advice on how to find out what is wrong. Basically what it is doing is this. At low speed it pulls, but as you gain speed it will not accelerate. The more gas it gets the higher the revs go, but there is no transfer of power to the rear wheels. It shifts fine and doesn't hesitate or do anything abnormal as the gears change, there is just no pickup. Has this 700r4 finally bit the bullet? If anyone has some ideas on how to check this thing out let me know. I'm going to pull the codes on the engine tomorrow to get an idea of what the engine is doing. The car is a 91 Ta 305 with 130,000 miles. I also put a new filter and a vette servo in not long ago.
Car: 1990 Iroc-Z
Burnt up clutch packs. They are grabbing at lower speeds, but slipping as demand (throttle) increases. If this is all that is wrong, you can replace them. I think this is where your problem lies.
Hotrodboba400
Dec 10, 2019 07:07 PM
BumpaD82
Feb 26, 2016 02:57 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
