Driveshaft vibration with 2.73's ?
Old Jun 21, 2003 | 02:58 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Has anyone ever noticed this with there stock driveshaft? The T/A starts getting some vibration at about 70 MPH and gets stronger the faster you go. The front end is all new and so are the tires, Ive had the tires re-balanced thinking that was what the problem but it was'nt. I can get the stocker balanced at Springfield driveline for $25 but I would'nt think the thing would be spinning fast enough to cause vibration with 2.73's.
Old Jun 23, 2003 | 05:31 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
ttt
Old Jun 24, 2003 | 07:45 AM
82camaro's Avatar
Car: 82 camaro SC
If it's out of balance, it could certainly cause a vibration. Some other things:
bent axle, u-joint, rear-end bearings/axle bearings, torque converter, bent wheel, slipped belt in a tire(can still balance ok). An experienced mechanic should be able to narrow it down by just taking it for a drive.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
loud91rs
Oct 5, 2015 10:05 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
64Chief
Sep 12, 2015 08:05 AM
