Torque Arm? Uses? Harm?
Old Jun 29, 2003 | 01:30 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I'm slowly fixing the problems with my newly purchased '87 IROC-Z.
Last weekend, when I replaced the tranny mount, I noticed something.
Now bear with me, as I'm a FWD guy, so my terminology may not be correct.
Anyway - There is a bar, I'm assuming the torque arm, that runs from the tail of the tranny to the rear end. (Runs along side of driveline)
I noticed that that I could move mine VERY easily. I mean, I bumped it and it moved. I checked out where it mounts and it looks not to be connected to the tranny.
What harm is there in this? I've got some wierd sounds coming out of my rear and drivetrain and I'm wondering if this arm being basically disconnected is having an effect.
Can anyone post any pics that have detail? I'm looking specifically for where this thing connects to the tranny.
Any help would be appreciated.
Old Jun 29, 2003 | 01:52 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's definitely supposed to be connected.
There's a bracket that bolts to the side of the trans, has a rubber bushing in it. There's a second bracket piece that clamps the bushing in place. Look and see if there is any such thing.
Old Jun 29, 2003 | 02:37 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
What are some of the side effects of having it disconnected?
Old Jun 29, 2003 | 02:46 PM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
You could roll the read axle over, you could send that bad into the pavement, and push it into the car, its very very bad, You NEED it connected, you can by the bracket from Jegs.
Old Jun 29, 2003 | 02:47 PM
Car: 84 Z28
Engine: 355c.i.
i had to move my car, just in the driveway with it dissconneted completly, everything i put the car in gear the bar went BANG against the underbody, it was hella loud, imagine if i went out and went WOT, it would be very bad.
Old Jun 29, 2003 | 02:54 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
I'm gonna get some pics later. I looked at it and I can't find exactly wher it connects.
Its definately hanging there. Maybe that's what it clunking in the rear. When I shift or floor it from a stop.
Is there a possibility that if it were off, as mine basically is, that the rear end could be off angle and cause the yolk to "bind" or make a howling in the rear?
Old Jun 29, 2003 | 04:38 PM
rjmcgee's Avatar
Accellerating isn't the big problem, going 60 mph and slamming on the brakes would be a big problem.
Old Jun 29, 2003 | 04:42 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Welp - I've determined that mine is bad - I got under the car and could shake it up and down by hand.
I called all 4 autoparts stores in town and they kept trying to sell me the whole bar, and that was if they could even find that!
Does anyone have a P/N or something for this bushing or does anyone know where to get it?
I _REALLY_ WANT THE FIX THIS THING.
Old Jun 29, 2003 | 07:01 PM
MdFormula350's Avatar
heres a link of where you can buy a poly one.
http://www.spohn.net/index.cfm?fusea...t&productid=91
this is my stock crap
Old Jun 29, 2003 | 07:02 PM
Old Jul 2, 2003 | 02:49 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
If you still havent fixed it yet, check this out :
Click Here
I got one made by Energy Suspension (poly) for $11.99 from Jegs, I got a poly tranny mount also so that I can do them both at the same time.
Old Jul 3, 2003 | 09:13 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
the torque arm bolts to the tailshaft of the tranny. you should have the tailshaft with the bolt holes for it. the bracket bolts go through the tailshaft, and connect to another bracket on the passenger side of the car.
when you pull your OG mount off, you might have some problems. when i first changed mine, the torque arm bracket where the mount goes was riveted into the sides of the bracket. so i could only cram my new mount in between the old brackets (from the OG bushing).
sounds really confusing, long story short, when i did my tranny swap, i pulled the brackets off completely and drilled out the rivets. hopefully this helps, and someone, somewhere knows what the hell i am trying to say.
lol
ima go lie down now.
Old Jul 3, 2003 | 09:33 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
[QUOTE]Originally posted by 1990GTA
[B]If you still havent fixed it yet, check this out :
Click Here
l
Instructions with pictures...
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
