Rear end sounds
Old Jul 4, 2003 | 11:46 PM
midlifeman's Avatar
Car: 1986 Trans Am
Engine: Mighty LG4
Rear end sounds
Hi guys,
I recently had a new cover put on my rear diff. I'm not sure if the shop was smart enough to add the limited slip lube with the gear oil. Would it cause any problems if they didn't and if so, what kind of problems?
Since then (could be a coincidence) the rear end has been making a noise when I am driving very slow. I noticed it while creeping along at a Wendy's drive through. It's a tinging, grinding kind of noise (hard to explain), and it only seems to do it once I have driven for a while and the rear end is warmed up.
Is my diff screwed or do you think it just needs some lube??
Old Jul 5, 2003 | 07:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds kind of more like maybe it needs a U-joint.
If it's a posi and didn't get the friciton modifier additive, it might groan or chatter going around tight corners at low speeds.
hectre13
Dec 11, 2023 08:14 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
