Need clutch/flywheel, any recommendations?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
My throwout bearing seized (see my sig) and ate the clutch as well... so now I need a new clutch! I had that thing done in September....
anyway, I was looking ar Hayes, but someone told me to go with Centerforce, as it has a softer pedal. I have no experience with anything pther than OEM, so gimme some ideas!
My flywheel is also turned to the max, so I need another. Once again, I ahve no experience... aluminum, steel, etc. Suggestions?
Car: 4
Engine: 6
Transmission: 5
I have had about every brand of clutch there is at one time or another, in one car or another; Hays, McLeod, Centerforce, Borg-Warner, Ram, all come to the top of my mind. Every single one of them was a high-quality product, and worked perfectly; I have no complaints whatsoever with any of them. Of course I've ony been driving stick shift cars for a few decades so far, so there might be a thing or 2 I haven't run across yet. But IMHO you just about can't go wrong as long as you stick with a good brand name, not just the cheeeeepest thing you can find that calls itself a clutch.
I have a Centerforce Dual-Friction in my car right now. This is the 2nd one I've had. Both of them have worked extremely well; very very smooth chatter-free operation in rush-hour bumper-to-bumper traffice, yet it hooks up like a piece of metal whan I stand on it.
Same goes for the flywheel. Any of the aftermarket ones will work fine. I would not recommend an aluminum one for a number of reasons; one of the lighter steel ones is a better choice for a street car.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i run the GMPP lightweight steel flywheel, and centerforce clutch, i like it, but unlike RB, i haven' run every clutch ever made
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
RB hit it.
I am running a Hayes billet steel flywheel and centerforce DF clutch. Works fantastic.
-Schultzy
-Schultzy
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, well I have a 1988 block... I didn't think I could use any flywheel from 86-back... or am I wrong?
Thanks for the info... Centerforce isn't too expensive, and I think that's the way I will go.
Car: 1990 Camaro RS
correct, you need a flywheel for a 87+ one peice rear-main.
i really like my centerforce, i am sure you will too, i think next time i will try out a spec clutch though.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
I have a hayes clutch and although I haven't had a chance to drive it yet the pressure plate was a bitach to put on. Had to use a ford tool to get the socket onto a couple of bolts that hold it on. The case/houseing thingy wasn't dimpled enough to accept a 1/2 drive socket.
Car: 92 Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 10 Bolt 3.73
I'm running a Centerforce D/F Clutch (#DF161056) also with the Hays (#10-530) Billet Steel Flywheel in my 92 (Tremec TKO trans). I've been very happy with this clutch setup. Best one I've tried in the thirdgen.
-Rich-
-Rich-
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Well, I got a great deal on a stock flywheel, $60 brand new. I was being quoted $300-$400 for it, as I could only find it at a dealer! All the parts yards and stores said they never have those... oh well.
Will a Centerforce bolt up to the stock clutch?
Also, I heard that you should get the clutch and the flywheel balanced together... is this true?
One last thing (lol), while I'm in there, I figured I'd replace the rear main seal. This just unbolts and comes out/off right? Any precautions I should know of?
Thanks again, don't know what I'd do without this board!
Car: 92 Camaro RS
The C/F clutch will bolt up to the stock flywheel.
Rear Main seal (on one piece rms engines) just pops right out with a small screwdriver. Wipe out the groove and pop the new one in.
-Rich-
-Rich-
