Need Immediate Help! please or advice
Old Jul 20, 2003 | 06:02 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
when my front seal blew out, i replaced it, and now the tranny wont shift out of 1st until rpm's reach 4k. And it slips pretty bad sometimes too. The fluid level is fine, but tranny leaks a little from around the pan(i replace fluid that's lost very often) what do you think guys? is it shot? or is it screaming for a rebuild?
Old Jul 20, 2003 | 06:36 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
If this is an automatic are you filling up your torque converter before installing it?
Old Jul 20, 2003 | 07:00 PM
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
the torque converter looked pretty full when i put everything back in, after it was installed i added about 10 qts altogether (after checking the car after each qt) and still drives like chit
Old Jul 20, 2003 | 08:00 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
With the TC you wouldn't know till it was too late. Even if you filled it up after it was started up then the TC would get screwed up as soon as you started the car. It would be too late to fill it up then. But if it was filled up before you put it on then I don't think that is your problem.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
