Little T56 swap help please...
Old Jul 22, 2003 | 01:39 AM
NonczRS's Avatar
Car: 1991 Camaro Convertible
Engine: GMPP 350
I am getting ready to do my 700R4 to T56 swap.... I already have the transmission, shifter, and clutch fork. All I really wanted to know is:
1)3rd gen or 4th gen pedals?
2)Will a 3rd gen hydraulic clutch setup work?
3)Does it have to be a 4th gen bellhousing?
thanks.
Old Jul 22, 2003 | 01:43 AM
NonczRS's Avatar
Engine: GMPP 350
Also...
Will my driveshaft still fit?
Old Jul 22, 2003 | 12:03 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
'84+ 3rd gen pedals bolt right in. 4th gen pedals will work but you'll have to cut the gas pedal off the assembly.
3rd gen master and slave work, but the pressure line isn't long enough. You could have one made, but it's best just to spend the $100 on a whole new set of T-56 hydros and not have to worry about it leaking or anything.
The GM T-56 requires a T-56 bellhousing. Nothing else will fit. Also make sure it's a bellhousing from an LT1 car, because an LS1 bellhousing won't fit either. Aftermarket T-56's are compatible with the T-5 bellhousing.
Your factory driveshaft will fit with a GM T-56....not sure about an aftermarket trans.
Old Jul 23, 2003 | 12:42 AM
NonczRS's Avatar
Engine: GMPP 350
Thank you very much....
Thats exactly what I needed to hear.
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
