clutch staying engaged
Old Jul 27, 2003 | 07:06 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
ok, i'm having a problem, i swapped a t5 into my 90gta, u bought a new PEP BOYS special clutch, and machined the flywheel, i did the work on a sunday so i used the brake lathe at work to machine it, later everyone told me i shouldn't have done that, but it was true,,
well the clutch pedal has always been very hard, u know get a cramp in the leg after driving in city for 20 minutes, and it's also grabbed VERY low, i'm gonna say about 1-2 inches off floor car will die if on the brake, when going into reverse, it will 80% of the time GRIND, like the clutch is staying engaged. well the t5 blew up, and i just installed a tremec tko and having some problems in 1st, 2nd and reverse...
i did add some spacers to the flywheel, BUT it think i ended up taking alot off the flywheel, would that disrupt the geometry of the slave and fork? i've tried double clutch in with little success, sometimes i can't even get into 1st and 2nd with the tremec. should i get a new flywheel??
thanks for ur help
jim
ps, ill post a tremec instal/evaluation once i'm set
Old Jul 31, 2003 | 10:48 PM
BANDITSBC's Avatar
Car: 90 gta
well bandit,
if i were u, i'd go pick up a new slave cylinder and try that,,, that won't work,,,,
then i'd spend $500 on a gm flywheel and clutch set up, cuz u must be nuts to cut it on a brake lathe,,,, that will fix the heavy clutch pedal but won't fix the clutch staying engaged
then i'd throw ur tools on the ground after spending near $3000 on a strong transmission that doesn't work followed by M.f'n everyone in site,,, that didnt' fix it either
then i'd spend 3 hours takin measurments of ur master rod/pedal set up, slave throw, check clutch fork for straightness, u'd probable started to get confused with some of the measurments
then i'd put in the master cylinder that ur father got u at lunch time, and that will fix it
i guarantee it!!!
good luck buddy
Old Jul 31, 2003 | 10:51 PM
BANDITSBC's Avatar
Car: 90 gta
wow bandit,,,
u are the #1 parts changer i know!!!! i don't know how u came up with that, u didn't even see the car u were just some guy off the intenet in a help forum,,,
SPECTACULAR!!!!!
hey all u guys that helped me out,, thanks alot!
i just hope someday i can help u
jim
hey guys if ur clutch doesn't disengage it could be ur master cylinder!!
later
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
