U-Joints and is this quite right?
Old Aug 2, 2003 | 01:53 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Ok i have searched all over and have come to this conclusion when changing U-Joints in these cars; If you don't have a press or a vice and a back up vehicle, you have to take the car to a shop to have them changed. Is this reasonibly correct? I am a college student who is broke most of the time so i can't buy the tools and the damn things are getting kinda sloppy.
Old Aug 2, 2003 | 04:05 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Nope...they can be changed (rather crudely) using a hammer and a couple of large sockets, or if you have a large enough vise it can be used in lieu of said hammer.
And you'll need a torch to remove that material (I forget what it is offhand) GM originally used to hold the joints in place.
Pete
Old Aug 2, 2003 | 04:23 PM
ede's Avatar
ede
you can also rent a ball joint press from auto zone and use that for u joints.
Old Aug 2, 2003 | 04:34 PM
Jokerman's Avatar
Hmm, so ya its a shop for it then. I lack a torch and don't really feel like beating on it with a hammer or trying a ball joint tool seeing as i only have this one car and can't afford to have it down for long just sitting in the garage. Thanks for the info though and if anybody else has info on it go ahead and post it.
Old Aug 2, 2003 | 04:39 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Sure, take it to a shop and watch them beat on it with a hammer. We have a press at work, but most techs there don't like trying to balance a 6ft driveshaft out of a Suburban while operating the press, so they just use sockets and a hammer. You don't need a torch either, you can shear the nylon injected caps during removal.
Old Aug 3, 2003 | 10:53 AM
Jokerman's Avatar
Hmm in that case i may just try it. Still gonna atleast call around on a shop though, see if it needs to be balanced and how much that would run while its out. thanks for the info.
MrJ
Jun 5, 2002 11:33 AM
86Chicken
Jun 16, 2001 12:02 PM
