rear end noise
Old Aug 7, 2003 | 12:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
rear end noise
hi guys, i had a speed shop install a new takeout auburn posi unit with 3.73 gears, and all new bearings including the axle bearings, it is a 28 spline unit, i noticed that sometimes, not all, when making a left turn kinda sharp, i get a moaning.., rubbing sound out of the right side of the rear, what would cause that?? they say they put the limited slip additive in it, could it be the brakes? they are drums, and i noticed they're not adjusted correctly after they did the rear.
Old Aug 7, 2003 | 12:50 PM
ede's Avatar
ede
if it's not gm additive i'd drain it and refill with gear oil and gm additive.
Old Aug 9, 2003 | 12:06 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
anyone else have a suggestion?, it doesnt sound like chatter it sounds like a big rubbing sound
Old Aug 9, 2003 | 01:03 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No need for another suggestion. Any other suggestion would be wrong.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
