rear swaps?
Old Aug 13, 2003 | 08:32 PM
CamaroJSU's Avatar
rear swaps?
Just to make sure i have a junk 86 TA, with disk brakes and posi 342. Im swaping it into my 92 RS convt. The rear ends are the same right. Just want to make sure.
Old Aug 13, 2003 | 09:26 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Are you sure it's a 3.42? Because I thought the T/As got the 9-bolt that year and 3.42 is a 10-bolt ratio. Maybe it's a 3.45 rear???
Either way it'll bolt right in. If the RS has a drum rear you'll want to swap the prop valve also.
Old Aug 13, 2003 | 09:39 PM
Flyte risk's Avatar
Car: 85 IROC
Engine: tree-oh-five
Transmission: 700, but the T-56 is laying on the floor
The rears will swap right accross.
If your going from drum to disc make sure to swap out the parkling brake cables as they are different. For the prop valve, I modified mine since I didn't have the correct disc unit. Look back for a post on removing the proportioning piston and spring from the valve. I did that to mine and haven't had an issue. I know several other here have done the same. There is even a post complete with pics if you search on the whole issue.
NOTE: I do not endorse anyone modifying their braking system unless they understand that the results may cause serious issues with safety. I am only relating my experience. It is also noteworthy to add that I run a front compound pad on my rear brakes. I do not know if rear compounds are harder of softer so your results may be very different than mine.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
