Q about T/C lockup wiring, please help
Old Aug 16, 2003 | 08:35 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
It took me all damn day but I finally got the Transgo Reprogramming 2&3 and the shift Kit in my 700 today. What a PITA.
Anyway my question is this, my car doesn't have a computer but I am keeping the lock up convertor. The other night I was talking to dana about it and he told me how to hook it up but I think I forgot, this is what I remember.
Run a hot wire to the terminal A on the plug in at the trans. that wire goes to the solenoid, then a black wire goes to the (I'm going to call it a pressure switch)on side of the valvebody, and it needs to be naturally open. I am about 80% this is what he told me to do.
When I apply to the A terminal it will power the solenoid and lock the convertor up, I have the power wire hooked up to a vacuum sensative switch. What does the black wire going to the pressure switch do?
Any help would be appreciated, I am planning on putting the trans in tomorrow and I want to have it right, if its not I will drop the pan after I find out.
Jason
Old Aug 17, 2003 | 08:08 PM
88TAJeff's Avatar
Car: 88 T/A
If you wanted, you could hook up a relay to lock up your TCC in 4th only. This stops the annoying lock/un-lock in 3rd. If you want to do this, reply, and I'll check my wiring again.
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
someone972
Aug 30, 2015 12:52 AM
Bryan F
Aug 27, 2015 07:28 AM
Eric-86sc
Aug 24, 2015 09:01 PM
