bent axel shaft on 9-bolt
Old Aug 19, 2003 | 02:56 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
hi, a while back i curbed my back drivers side tire pretty hard. i thought i just bent the rim but apparently the drivers side axel shaft is bent. i was reading another post about changeing the shaft on a 10-bolt, but is it as easy on a 9-bolt? what exactly do i need (tools, replacement bearings, grease?) to do this job and aproximately how long "should" it take? im totaly inexperienced when it comes to the rear end of my car, but i am a fast learner and im sure i can do it myself. i am 100% sure it is a 9-bolt borg warner with limited slip.
Old Aug 19, 2003 | 05:20 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Remove the wheel, the brakes and the 4 axle flange retention bolts, then the axle will slide right out. You don't even have to remove the rear cover.
Miles
Old Aug 19, 2003 | 06:30 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
And if you only jack up the side you're working on, you won't even lose any gear oil.
Old Jul 18, 2004 | 12:09 AM
Randel '86's Avatar
Car: '89 IROC-Z
I did something very simular, and I think my axel shaft is bent to. I replaced the rim, and I still have a good 5 degrees on pitch when I am driving on that wheel. You guys think that is what is wrong? Could it be anything else?
Old Jul 26, 2004 | 03:14 AM
doc76239's Avatar
Car: 1989 FIREBIRD FORMULA WS6
Engine: TPI 305
I have an 89 firebird formula WS6, My drivers side axle shaft is bent. I can't find ant replacement shafts. Thet are real hard to find, so before you start tearing your 9bolt apart, find the parts first. I had to buy a posi 10 bolt and swap my 9bolt out. moser engine ering will build custom axle shafts at 150dollars a piece, but I needed bearings. After I added up the price of one new shaft, bearings, and shipping, a used 10bolt posi was cheaper. I still keeping my 9bolt. I want to rebuild the whole cars and keep the original parts on it. Good luck in you hunt for 9bolts and there parts.
dbrochard
Oct 3, 2015 12:43 PM
Zell1luk
Sep 29, 2015 10:36 AM
6998poncho
Sep 25, 2015 02:56 PM
6speedIROC
Sep 13, 2015 01:29 PM
dbrochard
Sep 7, 2015 09:41 AM
