th350 rebuild question: Bushings
Old Aug 23, 2003 | 06:17 PM
TwnTrboZ28's Avatar
I rebuilt my th350 with a Huges Performance kit and installed the new bushings that came with the kit.
Here is the problem:
When I went to put the pump assembly back in, it went in real hard, like the sealing rings or the bushings were really tight. It went in all the way, but I cannot turn the input shaft with my hand.
Is this OK?
Old Aug 23, 2003 | 10:02 PM
Nordbert's Avatar
The input shaft is usually hard, if not impossible, to turn with only your hand. I use a pair of Vise-Grips to turn it and check end play. The pump should go in easily. If not, the pump halves may not be aligned. I use a small block Chevy valve stem ( or 11/32"
drill bit) to align the pump halves, then tighten a large hose clamp around the body, and tighten the bolts. I put the seal rings and o-ring on the pump after I fit the pump to the case and set the endplay .
camaro1185
Oct 26, 2015 06:51 AM
Fred SS
Oct 12, 2015 11:27 AM
Nervous2
Oct 8, 2015 10:53 PM
327IROC85
Sep 23, 2015 12:11 AM
89newfun
Sep 16, 2015 09:28 AM
