Tranny Sealing Ring Kits
Old Aug 28, 2003 | 06:10 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I have a th-350 in my 82 Z28 that is leaking pretty good. It is leaking from several locations and even from the speedo cable hold down bolt, that is broken off.
I was wondering what kind of Sealing Ring Kits would you guys recommend?
I have found these:
http://www.bulkpart.com/cgi-bin/miva...ory_Code=350rk
http://www.coanracing.com/Components/Turbo350Comp.asp
http://www.tciauto.com/service_kits/..._ring_kits.htm
Also how hard is it ro replace the seals and o-rings? How much work is it? Do i need any special tools? Do i need to remove the tranny?
I just want to band-aid this thing up until i get a 200-4r.
Thanks alot!!
Old Aug 29, 2003 | 05:47 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Nobody?!
Old Aug 29, 2003 | 10:33 PM
Nordbert's Avatar
Your local tranny shop should have a kit for about $20. The seals needed to stop the leak could cost even less. BTW, a rebuild
kit is only $68 from www.northernautoparts.com. and it includes
some thrust washers and bushings.
Stryker412
Sep 7, 2015 09:11 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
