Manual tranny fluid check
Old Sep 9, 2003 | 10:23 AM
Connan1's Avatar
Car: 1992 Camaro RS
Engine: 5.0 Liter V8 TBI
Transmission: 5-speed manual
I understand that the transmission fluid on a manual is checked by removing a plug from the side of the transmission case. I want to be sure that I found the plug. Is it on the right side of the transmission case (driver’s side of the car), somewhat high, and above an electrical sensor which is also plugged into the transmission case? This plug is not a nut or bolt, like on the motor oil pan, but a big screw which is turned with, not a flat-head or Phillips-head, but the six-point-star head (Allen-head?).
Am I right? Did I find the plug?
PS: It’s a stock 92 Camaro RS with the 305 V8
Old Sep 9, 2003 | 12:54 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
That's the one. Should be about 3/4" in diameter.
Old Sep 9, 2003 | 12:59 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
NO!!!!! Not that one!! That's not a plug, that's a pin that a piece of the shift linkage sits on. If you take that out the piece will fall out and you'll have to tear the trans down to put it back in.
The one you want is on the pass side. There are no electrical connectors anywhere near it. It's about halfway up. Should be a 3/8" square drive. There's another similar one at the bottom of the same side of the case for draining it.
Old Sep 9, 2003 | 01:25 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Hope he read this in time......
Old Sep 11, 2003 | 12:39 PM
Connan1's Avatar
Car: 1992 Camaro RS
Thanks RB83L69. The square drive plugs on the right side of the transmission case, got it.
If it needs lubricant, would you use Automatic Transmission Fluid or Gear Oil? Which lubricant did the car originally come with?
Old Sep 11, 2003 | 12:53 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
ATF
backtothe80s
Sep 5, 2015 12:39 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
