Carrier Question
Old Sep 12, 2003 | 03:29 AM
86irocss's Avatar
Carrier Question
I have a posi disk rear with 3.27 gears, my question is: Can I put diffrent size gears in that carrier or do I have to get a new carrier. Also when I change the gear ratio do I have to get a new speedo gear for my speedometer to work right?
Old Sep 12, 2003 | 05:27 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Yes, you can change gear ratio with that carrier as long as you USE 9-bolt parts. Depends on the gear change for the speedo.
Double check what type rear you have, before ordering any parts.
Old Sep 15, 2003 | 02:49 AM
86irocss's Avatar
My other question on that 3.27 carrier, is this the one that I can put in a 3.41 or higher number, or is this the one that I can't put in anything higher than the 3.27?
Old Sep 15, 2003 | 02:08 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
The series 3 carrier for a 9 bolt will hold 3.2x - 4.1x ratios. More 9 bolt information is available at www.9bolt.com
Miles
Old Sep 15, 2003 | 04:14 PM
86irocss's Avatar
Miles
Thank-you for the info
hectre13
Dec 11, 2023 08:14 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
knight72
Aug 10, 2015 09:32 PM
