lower gears in my 2 series 9 bolt
Old Sep 16, 2003 | 12:08 AM
killerIROC's Avatar
I have a 9 bolt with a 2.77 gear ratio. Now, I know that that has a 2 series carrier and if i want to go with 3.42 or 3.70, it would need to be a 3 series carrier. Can I convert my 9 bolt to a 3 series carrier and if so, what does that consist of. If not, what can I do if I want to stay with the 9 bolt but with a lower gear ratio?
Old Sep 16, 2003 | 05:32 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Buy a 3-series carrier, and a gear set. The carrier is a piece that bolts inside the rear end, that the ring gear is attached to.
Parts for that rear are not cheap.
Old Sep 16, 2003 | 10:09 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
You will need a series 3 style carrier. Then you can go with a ratio up to 4.10.
Miles
Old Sep 17, 2003 | 12:44 AM
killerIROC's Avatar
thanks guys, thats what i thought, but i didn't know for sure.
Old Sep 17, 2003 | 07:52 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
You don't need a 3 series carrier. There are several companies that make adapters that will do the job perfectly for a series 2 carrier, for much cheaper than a new carrier would cost. Unless your series 2 carrier is toast, keep it and buy an adapter along with your gear set instead.
Old Sep 17, 2003 | 10:27 AM
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
This is for a 9 bolt, not a 10 bolt. The design of the carrier on a 9 bolt does not allow for a conventional style spacer and proper ring gear alignment.
Miles
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
