Vibration at 85 MPH
Old Sep 18, 2003 | 10:44 PM
86iroctpi's Avatar
Car: 86 IROC
Vibration at 85 MPH
I have a vibration when my engine is under a load at 85 mph and above. By load, I mean going up a slight grade on the Interstate. Going down a grade it stops. I have had the tires balanced twice, with no change either time. Has anyone had a similar problem? Or would anyone know where to start looking for a possible culprit?
Old Sep 18, 2003 | 10:51 PM
chevycamaro1984's Avatar
vibration
i changed my rims and tires i had the vibration at 65-70 i changed and i got none now its sweet ride now hahah
Old Sep 19, 2003 | 02:39 AM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
for some reason i get a vibration when im going over 140km's (i have no idea what the conversion would be) but i would asume it has something to do with my slightly bent axel shaft on my drivers side, jack up your rear end, turn on your car and put it in drive. then hop out and check if your tires are wobbeling around(this works better if you have a friend to check while you sit in the car getting the brakes ready ) im not entirely sure this would be the cause though. mabey its your shocks/struts?
Old Sep 19, 2003 | 02:29 PM
86iroctpi's Avatar
Car: 86 IROC
The shocks are new. Shouldn't be that, but I will check the axels.
Old Sep 20, 2003 | 03:38 AM
rscamaro305's Avatar
How are the tires? When tires get worn they could cause problems like that. Just a thought.
Old Sep 20, 2003 | 11:01 AM
86iroctpi's Avatar
Car: 86 IROC
The tires are fairly new, less than 10,000 miles on them.
Old Sep 20, 2003 | 09:00 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
anybody ever thought that it might be the exhaust shaking.... ive had similar vibrations in my last 2 chevys....always when your going up a hill or sumtin...and you can get rid of it by giving it a healthy amount of gas...
ive always thought it was the exhaust...and since my muffler and tailpipes are off right now ive had no more vibrations.
Old Sep 20, 2003 | 09:44 PM
onebinky's Avatar
could be a flat spot on the tires from stomping the brakes, could be warped rotors, could be a tire is off balance, could be a bent axle shaft, could be a bent or off balance driveshaft, a bent rim, or a messed up spindle. I suppose it could also be a gear or shaft in the trans bent or off balance, but I don't know much about that area Basically anything that rotates on the car could be a culprit.
Good luck finding it,
Matt
Old Sep 21, 2003 | 09:50 PM
yanfoo's Avatar
Car: Malibu 80, T/A 87, S-15 87
Engine: 267 Bu, 305 T/A, 350 S-15
Transmission: Auto Bu, 5spd T/A, Auto S-15
my car does this also at 140kmh and higher, if i give gas it vibrate a bit less, let go the gas and woaahhh crazy vibes, not pleasent at all. rims balancement is not perfect, but look good enough, after the exaust swap it felt better, before it was at 120kmh.
I'll check it on a lift when i can.
Old Sep 22, 2003 | 01:36 PM
86BirdSE's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
BALL JOINTS
If they have slop, they'll cause higher speed vibrations in the front.
If it's in the rear, worn out bearings will do the same.
Old Sep 24, 2003 | 02:50 PM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
Please do not try this if you do not know what your doing..Just have an image in my head thats all..some 14 yo tries it on ramps instead of stands...
Old Sep 24, 2003 | 11:25 PM
86iroctpi's Avatar
Car: 86 IROC
How hard is to replace the bearings in the rear? Could worn u-joints couse this?
Old Sep 25, 2003 | 01:23 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
its the exhaust!!!!! im not ****ing kidding.....just take your muffler and tailpipes off and youll get no more vibration.....or get a bigger freeflowing exhaust if your not into that.
Old Sep 25, 2003 | 08:58 AM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
OK check the u-joints...then HAS the driveshaft been OUT before....EVER????
If the driveshaft is 180 OUT of sync with the rear this will happen....I put my shaft back in once not paying attention to the PAINT COLORS and ran it up the road...ABout 85-90 MPH it would SHAKE pretty good.... All I did was like up YELLOW paint sde to YEllow side of the rear and it went away...I was 180 OUT initially..
GM paints i side of the DS and 1 side of the rear yoke YEllow ...you must match yellow to yellow.....Has to do with how the drivetrain was balanced..
Old Sep 25, 2003 | 11:29 AM
86iroctpi's Avatar
Car: 86 IROC
I have a Pace-Setter exhaust. I'm sure it can handle everything my 305 can throw at it.
The drive shaft has been out. I will check the marks.
Old Sep 26, 2003 | 11:56 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
yeah but do you have the exhaust in there really tight...it can still vibrate around alot of times.
Old Sep 27, 2003 | 03:11 PM
Psyte's Avatar
thats actualy really interesting (the drive shaft being unbalenced) i know for a fact mine has been out before, but i had no idea it needed to go back in a certain way. im gona check that out. ive been under there countless times and never saw any paint to match up though.....
Old Sep 27, 2003 | 04:43 PM
onebinky's Avatar
I've never seen it on a thirdgen either, but if I remember right my 2001 TA had it. I don't know if all the 4th gens do though
Old Sep 27, 2003 | 06:46 PM
AustinT's Avatar
I have the exact!!! same problem. The only thing that I have not replaced is the control and panhard bushings. I thought maybe the pinion angle is off under throttle. my vibratiion starts at 70 mph. I thought it had something to do with the tranny or clutch because I would push in the clutch or put it in nuetral and it would stop. Finnally I realized it just vibrates when there is torque on the drivetrain, Like going up a hill. I can decend a hill at the same speed and it will not vibrate. Also the vibration is not engine rpm related becuaue I can drop from 6th to 5th and it still vibrates. Good luck maybe somebody can answer both of our problems
Old Sep 28, 2003 | 10:45 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
maybe its the steel driveshaft....go aluminum and i hear it gets rid of any vibrations.
Ed1LE
Sep 30, 2018 09:14 AM
darwinprice
17
Oct 11, 2015 11:51 PM
gt4373
Oct 8, 2015 10:37 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
InfinityShade
Sep 18, 2015 08:32 PM
