what did i break. sudden, LOUD gear whine
Old Sep 23, 2003 | 10:52 PM
darbleinad's Avatar
Car: 84 Trans Am
Howdy fellas,
i am in need of your help. this evening i was driving home and i decided to stop and test out my recently installed posi unit. i did 3 launches from a stop and each time the posi worked correctly and hooked pretty decent. i did this after driving the car for 40 minutes (15 city, 25 highway), so everything was nice and warm and lubed. however, when i went for another drive on the highway (2 hours later), i noticed a VERY loud whine coming from the rear end. it only does it when power is being applied. it does not do it when i coast.
i have just recently put in a used posi carrier and some used GM 4.11 gears (GM was stamped right on them ans so was 37 and 9, so i know they are factory 4.11s, most likely from an S-truck) in the rear end. i replaced all the rear end bearings and the pinion nut and crush sleeve. i had someone help me do the swap who has done them before. we carefully set the pinion depth and backlash (set to factory specs). i used amsoil series 100% synthetic gear lube (the series 2000 racing stuff) and their posi additive. other than this my 10 bolt is stock.
so what did i break? as we all know just because something is new doesnt mean it cant break, so did i wreck a bearing or have the gears come out of "alignment"? i could really use some help here. i could care less about the noise if everything is fine, but the fact it only apeared after i did some drag style launches makes me assume i grenaded something.
Old Sep 24, 2003 | 05:37 AM
ede's Avatar
ede
pull the cover and look. i'd check back lash too while cover was off, maybe even pull axles and carrier and recheck pinion depth and preload.
Old Sep 24, 2003 | 07:01 AM
darbleinad's Avatar
Car: 84 Trans Am
i definetly will be pulling the cover. i did this last night at about midnight so i didnt have time last night.
i am somewhat concerned about driving home to work on it. it seems to drive fine, no issues there, yet....but i am afraid that i will be do further damage.
i am assuming that i havent ripped the teeth off the gears cause it was still driving fine....but who knows. i will try to get the cover pulled today or tomorrow. thanks for the help ede
Old Sep 24, 2003 | 09:29 PM
darbleinad's Avatar
Car: 84 Trans Am
after doing some research and some investigating, i think it i may have trashed the pinion bearing. i will find out tomorrow when i have time to really dig into it.
Old Sep 27, 2003 | 01:21 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
or you peeled a tooth off the Pinion Gear. Happened to me just the other day. Gets real noisy real fast...will still drive....but not for long
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
BlackFormula
South East Region
Sep 8, 2015 09:59 AM
tgp1990
Sep 4, 2015 06:24 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
