which stall convertor?
Old Oct 3, 2003 | 04:01 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
what stall speed should i go with since i have a lt4 hotcam ?
Old Oct 4, 2003 | 01:08 AM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
With 218 degrees intake duration you could probably get away with a converter like mine, 2100 stall. It pretty much feels like stock converter with a tad more stall. If I power brake it I can only get the rpm's to like 1600 before the tires break loose. If your going for a real suck your eyeballs into the back of your head feel you need AT LEAST a 2400 stall. I would probably go with 2800-3100 stall just to be sure. This is about the limit of stall while retaining drivability.
Just wondering, hows the idle and throttle response of the HOT cam compared to the L98?
Old Oct 4, 2003 | 01:19 PM
demon138's Avatar
i havent got ita ll put together yet. i have i beam rods and they hit the cam so i gotta get h beam rods.
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
