Seal, Yay or nay? (700r4)
Old Oct 6, 2003 | 07:29 PM
PioneerCrazed's Avatar
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Do you guys know if their is a seal, or gasket between the tranny and the tv cable boot?
I replaced this cable and now it drips continuosly, has to be something to do with it, and it's very tight...
Thanks for any info...
Old Oct 6, 2003 | 07:52 PM
Pro Built Automatics's Avatar
First "do not" overtighten this as you will crack it. Yes, there is a top hat type seal that goes in there. When installing this seal the area must be perfectly clean, and use a little oil on the seal when you install it so as not to rip or tear it.
Old Oct 6, 2003 | 07:55 PM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
First off, thanks for replying. Now by cracking, what part are you talking about, the boot of the actual cable or the seal? Also, this hat seal, is it a completely seperate piece from the cable. Because I don't have anything besides the cable hooked up.
Old Oct 6, 2003 | 08:32 PM
It is a seperate seal. You will crack the TV cable itself by overtightening.
Old Oct 6, 2003 | 09:43 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Typically the old seal will sneak out with the old cable when you remove it... Unless you pulled the seal off of the old cable and put it in before you installed your new cable, it is likely to be missing...
1Aauto
Sponsored Vendors
Oct 19, 2016 08:50 AM
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
loud91rs
Oct 5, 2015 10:05 PM
Dragonsys
Sep 25, 2015 03:51 PM
6998poncho
Sep 25, 2015 02:56 PM
