i have a 3.42 gear, so what would i need to have posi, i was told i needed some kind of unit and i could mabye do it myself.....thanks
Check out the Powertrax no slip system, they are pretty good and very easy to install. If you go with a posi unit you have to take the gears out and reset them up. The Powertrx is quick and easy.
Not cheap they are 399.99 plus tax at www.jegs.com.
zman1969
close
- Join DateJul 2003
- LocationDFW
- iTrader Positive Feedback100
- iTrader Feedback Score(9)
- Car90 Formula 350
- Engine350
- Transmission700r4
- Axle/GearsDana 44 3.54
- Liked:205 Times in 147 Posts
Quote:
If you have an 88 and later slp offer low mi zexel torsen posis for 100 bucks! if 87 and older watch e-bay used 3 series usually go for 100-150 range with 26 splines, avaid the "gov-lock" units.Originally posted by MiscCamaro
