Pre-bled gm hydrolic sytems
Old Oct 21, 2003 | 01:21 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I keep seeing people talk about getting these. What is it?, the clutch master and slave cylinder and resevoir that comes filled and pre-bled? What is the part number, and how much is it? I am assuming I could get it from any chevy dealer?
My stuff is leaking, everytime I push in the pedal a few drips of brake fluid leaks onto my floor.
Old Oct 21, 2003 | 02:17 PM
ede's Avatar
ede
it's pretty much what it sounds like, all the parts connected by a line and prebled. gm is the only source i know of. do a search i think the PN has been posted here before
Old Oct 21, 2003 | 03:53 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
what ede said. i bought the entire assembly when i swapped my auto for the tko last january. i'll check back when i get home and post the part number if you haven't got a reply yet by then.
any gm dealer should be able to order it though. shouldn't be too hard to find... i don't think that they sell the components separately any more.
-Schultzy
Old Oct 21, 2003 | 04:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yup, I've done it too.
There's a bunch of part #s, at least 4 last time I checked. I have no clue what the difference is. I can tell you that when I needed one, my local dealer network didn't have the one that would have been most logical for my car (I have 84 stuff in my 83 car); so I tried for the next most logical, which was 87 or something, no luck there either; but, they had the one for a 90 or some such, so I bought it. Fit perfect and works great.
Expect to pay a little over $100, maybe $120.
Old Oct 21, 2003 | 09:42 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
awesome guys, yeah I was doing seaches and I could find anything becasue I didnt know what to exactly call the part. I will have to stop by gm tommorow and order one. thanks alot!
Old Nov 11, 2003 | 02:34 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
I just got that assembly through my work today, the part number from GM is 12527718. Thats the entire assembly, slave, master, resevoir, and the lines. Pre-bled, full, ready to install.
Old Nov 13, 2003 | 11:34 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
What did you pay for it abird? I will get the discount through work too...
codeysabatini
Nov 10, 2015 04:07 PM
hydrolic144
Oct 4, 2015 08:23 PM
hydrolic144
Sep 8, 2015 06:59 PM
hydrolic144
Sep 8, 2015 06:55 PM
hydrolic144
Sep 4, 2015 09:48 PM
