this might help
Old Nov 13, 2003 | 12:22 PM
Horrible01's Avatar
Car: 91 camaro rs
Engine: 350 sbc
Transmission: b&m 350
Axle/Gears: borg warner 9 bolt
will this work??
I hear that when you put a fourth gen rear on my 91 rs limited slip the wheels wont fit and i will need fourth gen wheel. can i just swap the drum brakes over to keep the wheels stock?
Old Nov 14, 2003 | 01:11 AM
onebinky's Avatar
As far as I know, it's the length of the axles and axle tubes that give it the higher offset. The brake setup wouldn't have anything to do with it.
Hope that helps some,
Matt
