Restriction in hydralic clutch lines?
Old Nov 16, 2003 | 06:22 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Has anyone heard anything about a restriction in the lines going from the master cylinder to the slave cylinder? Which would not allow the clutch to engage as fast causing gear grinding when trying to shift rapidly? Anyone have any poop on this?
Old Nov 17, 2003 | 01:35 PM
likeistoleit's Avatar
Car: 87 Iroc
Transmission: Tremec Tko
I believe the problem that you are referring to is common in the LS1 cars, I saw an article on enlarging the passage for quicker response. I havent heard of this problem with a 3 rd gen setup
Old Nov 17, 2003 | 02:28 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the only place ive heard of that is on LS1 cars...
Old Nov 19, 2003 | 10:01 AM
Car: 1985 IROC Z-28
Engine: 355
Axle/Gears: 3:73
Thanks, guys. I think I have that problem. Maybe if I drill out the ends of those metal fittings, it would allow quoicker shifts..........
although it could be just that *****T-5(Can't complain. 160K and it's still alive, although the last 5k has been tough on it......with 400+horse) Also could be the fact that I'm running 90weight lube. When the car was new, the trans leaked a little. Back to the dealership. I talked to the tech, he told me that the trans came with ATF in it. He replaced it with 75W-90, and told me that ATF was NOT the hot ticket for the trans,. I've been running it ever since. New syncros, BTW, so it's not those. Any Ideas?
Drone358
Dec 10, 2015 08:16 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
