Rear end fluid change, what weight fluid to use??
Old Nov 17, 2003 | 01:49 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I have a 10 bolt 3.42 limited slip disk brake rear end from a 93-97 F body. I want to service the rear before I install it in the car and when I went to the auto store they had so many different weights for rear end fluid.
So lets say I planned to run regular rear end gear oil whats the recommended weight?
What if I went with synthetic, what weight would I run?
Old Nov 17, 2003 | 06:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
Only get gear oil from the dealer for the rear. You NEED to put the posi additive in there. if you dont you will notice that after a few weeks the clutches will get noisey. Just go to the dealer and get the 2 bottles of the recommanded oil and the little bottle of posi additive. I have ben doing this for 6 years and have not had any problems. Just my 2 cents. As for synthetics, my buddy put Mobil 1 synthteic in his rear end and hir rear started making noises.
Old Nov 20, 2003 | 01:26 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I agree. Not knowing any better I put straight 90W in and the clutches started talking about 3 weeks later. GM designed it so you have to use thier additive, bastards.
Old Nov 20, 2003 | 01:28 PM
ede's Avatar
ede
don't use any additive but what gm sells, as for oil i use 75w-90 M1 or the same in amsoil
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
BlackBoulder
Aug 11, 2015 11:15 PM
