quick question
Old Nov 18, 2003 | 03:49 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
quick question
when i was removing my 3.23 gear from the old open rear one of the bolts broke in the ring gear. i dont have much money right now so i was wondering if it would be ok to install the ring gear minus one bolt holding it to my slp torsen posi. obviously this isnt ideal, but if i take it easy on the car should it be fine until i can get the cash together to buy a 3.42?
Old Nov 19, 2003 | 02:39 PM
ttt
Old Nov 19, 2003 | 03:52 PM
ede's Avatar
ede
i'd say no
Old Nov 19, 2003 | 05:16 PM
mikesz1984's Avatar
Car: 1984 z28
i would not reccomend driving a car that you did that to, everything that has a bolt on it is bolted for a reason, it all has to do with balance and warpage in this case. With that bolt missing it might be warped enough to cause the ring gear to connect and cause wear
Old Nov 20, 2003 | 08:08 PM
i see. well, you think it would be ok just to limp it to where i store it during the winter? its like a 10 minute drive and i dont have to go above 30mph... if you guys SERIOUSLY think it will mess up my rear end just doing that and a return trip in may or june, i will look for other options. thanks.
Old Nov 21, 2003 | 05:20 PM
ttt
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
