Rear End Rebuild
Old Nov 20, 2003 | 06:36 PM
91rsv6's Avatar
Car: 87 IROC Z
Engine: 5.0 TPI
Rear End Rebuild
Well since my car was stolen the rear lasted me one week then i shattered the pin into two pieces. All the posi guts stuck to the pans magnet.
What i wanted to know is $850 a good price for a Rebuild with a new Eaton posi, 3.73 gears sound about right.
Also pulled axles and splines were wore bad so for 125each I will be upgrading to 28 spline drop forged ones.
Old Nov 20, 2003 | 06:46 PM
vjo90RS8's Avatar
Car: 2002 Z28
that sounds pretty good, i spent about $700 to have mine rebuilt, i supplied the deluxe rebuild kit, 3.73 richmond gears, and SLP take off posi (~400 in parts) and paid $300 to have it all installed.
Old Nov 20, 2003 | 09:25 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
rearend rebuild
if your intrested I have everything you need to rebuild your rearend and make it stronger
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
