rear end questions
Old Dec 3, 2003 | 03:14 AM
titeride85's Avatar
rear end questions
which type of rear will work best for my ride? I have a 91 rs with a mild 350 and a turbo 350 trans. I have done a few suspension mods (SFCs, boxed LCAs, and shocks).
basically, I am going to be doing some upgrade work to the motor soon and want a rear to match. It will be primarily street driven with few track passes. I want to be able to launch without the car going sideways but I also want to have fun by being able to corner and keep streetability. so what will be best?
Open
Spool
Limited slip
Posi
Keep in mind that I have next to no experience in the rear axle. I have no doubts about my ability to do the work but I am not sure of what rear I should go with or exactly why. so please help. thanks.
Old Dec 3, 2003 | 05:10 AM
ede's Avatar
ede
you for sure don't want a spool or an open rear and the only differance between a posi and limited slip is the spelling that leave you with either a limited slip or posi, depending on how you spell it.
Old Dec 3, 2003 | 08:36 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I got a hold of Gov-Loc. I bought it off ebay for $50.00 and it was new. Its a "limmited slip", I had a 3:73 richmond installed with Moser axles (had to because the new dif was a 28 spline and my 10 bolt was a 1987 26 spline unit) and a Jeg's aluminum rear end girdle. The rear end is awsum, it locks flawlessly every time, and I don't have any chatter or other noises. It was a very stout piece and well worth the $50.00.
If I had not found that deal, I was planning on getting the Eaton clutch type posi from Jeg's. Its around $450.00 I feel would be a better choice than the Auburn because it is totaly rebuildable, the Auburn as far as I know isn't, because it is a cone type posi.
I am planning on installing a Ford 9" in a year or two. For now, the 10 bolt will handle the power my 355 has if I drive sensibly, and don't use street slicks or any slick of any kind.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
