what usualy happens when rear goes out?
Old Dec 3, 2003 | 06:21 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i've never had a rear end go out. what usualy happens? is it usualy something that goes out and you can't move or do you hear something and you can drive it to get home or something? thx.
Old Dec 4, 2003 | 01:17 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When the gears break, sometimes the car will still move, sometimes it won't.
It will make a lot of noise, a clunking sound or loud tapping.
Here are 3 pinion gears that my brother has gone through (he is on his 11th set of gears now)
I tossed out the latest pinion gear that had 1/2 of the teeth wiped out, should have taken a pic of that one.
Old Dec 4, 2003 | 01:53 AM
CamaroX84's Avatar
Those are factory gears I take it???
Old Dec 4, 2003 | 01:56 AM
Zepher's Avatar
Nope, Richmond and Motive.
Old Dec 4, 2003 | 07:48 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Man those gears are pretty!!! Mine when I pulled them was more like the 1/2 gone one you referred to!!!
Mine was from beating on a 13 year old stock rear end though. I snapped a couple teeth off, but being a newB had no clue what I was listening to. Drove it about 30 minutes back to where I live, and about 5 minutes away, POP... CRACK!!! Snapped about half of the teeth off, and right as I came to a stop, the rear locked up. It makes a hellacious noise, even with one tooth missing. Something I will never ever forget.
Old Apr 20, 2019 | 07:00 PM
NoEmissions84TA's Avatar
Re: what usualy happens when rear goes out?
xxx
Last edited by NoEmissions84TA; Apr 20, 2019 at 07:02 PM. Reason: posted wrong place
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
