700R4 prob.
Old Dec 8, 2003 | 06:37 PM
thabrotherhood's Avatar
700R4 prob.
Hi.
I just swapped in a TBI 350 into my 89RS. (Had 305 TBI before).
My tranny feels like it is slipping through the gears from time to time, and it vibrates sometimes, until i let up on the gas, then if i depress it again, the vibration isn't there. (torque converter?) I also don't seem to get many shifing problems at WOT.
The one other problem I've been having is that at high rpm's in 4th gear (WOT), it will climb to about 4-4500 rpm, then it will just slip at rev really high, like it just popped into neutral. Just let off the gas, and put my foot down again, and it is good. Also have the problem when going to WOT from a 60mph + roll.
Any ideas guys?
Old Dec 8, 2003 | 08:05 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
#1 Check your fluid level. I would get your trans fluid flushed and your filter changed. Don't just drop the pan, go take it to some shop that offers a trans flush with a T-Tech or something similar. Then go from there.
Old Dec 8, 2003 | 08:31 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
bad adjusted cable?
pull the tranny dipstick out n smell it...
if it smells burned, mnaybe some internal...
also as suggested, check the fliud level
Old Dec 8, 2003 | 08:50 PM
What would I need to swap from the 700r4 to a t-5 or t-56?
Old Dec 8, 2003 | 10:37 PM
Engine: 5.0 TPI
A t-5 or a t-56
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
