Coan vs. Yank
Old Dec 9, 2003 | 11:38 AM
CamaroX84's Avatar
Coan vs. Yank
Well, I've heard nothing bad about either of these converters, only a lot of good praise for each. I will need one for a 700R4 most likely. What makes the Yank so much more expensive (around 300 dollars I think)? I have around 440-450 HP, and plan on using a 100 shot or so. Any suggestions would be greatly appreciated. Thanks in advance.
Old Dec 9, 2003 | 02:19 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
An aftermarket TC that has TC lockup is usually more expensive than a non-lockup TC. Does the Coan have lockup? I am pretty sure the Yank does.
Old Dec 9, 2003 | 05:33 PM
CamaroX84's Avatar
Yes the Coan does. Thanks.
Old Dec 9, 2003 | 08:15 PM
Pro Built Automatics's Avatar
The Yank, like the Vigilante, has a large area lockup clutch (apx. 37 square inches) which accounts for the extra cost.
Old Dec 9, 2003 | 08:30 PM
CamaroX84's Avatar
What advantage does this have in racing and/or street driving? Thanks.
Old Dec 9, 2003 | 11:12 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
None!
However, it will be softer on your transmission and engine when you aren't racing. A TC without lockup will just keep spinning around therefore generating a whole lot more heat than a lock-up converter. So, if the Coan TC has a less effective lockup, than it will generate more heat under normal driving conditions than the Yank TC or Vig TC (freeway driving or higher speedzones like 40mph and up).
I ask for a second opinion on this, as I am no TC guru! I am Just some guy
Old Dec 16, 2003 | 03:25 PM
CamaroX84's Avatar
So the entire cost difference lies in the lockup mechanism?? Thanks again.
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
3.8TransAM
Sep 17, 2015 02:16 PM
sunbound
Sep 5, 2015 11:52 AM
C409
Sep 1, 2015 03:42 PM
