Breakaway converter?
Old Dec 16, 2003 | 09:16 PM
CogsRS's Avatar
Car: 87 Monte Carlo SS
Transmission: 200 4R
Hi, I just have a question about a converter I have. The stock converter has 3 threaded bolt holes, the new converter has 3 holes, no threads, just a plate welded on there with a hole. How does this work and attatch to the flywheel? Does this have anything to do with the converter being breakaway? I have no clue about this stuff. Thanks.
-Dan
Old Dec 16, 2003 | 09:25 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
Sup dan, the breakaway converter uses a nut and bolt combo, instead of the stock bolt-into-threaded-hole-which-likes-to-strip-out-a-lot. People sell "torque converter nuts and bolts," but all you're buying is a set of high grade, fine thread bolts that fit through the converter. It's fun gettin nuts up there, don't get me wrong (I had the breakaway.... or one of those TCI converters), and it's do-able, and not too bad. Good luck.
Old Dec 16, 2003 | 10:14 PM
CogsRS's Avatar
Thanks Dan... Thats what I kinda thought it was, but theres no nuts and bolts with it, where would I get these from?
Old Dec 16, 2003 | 10:19 PM
Stingraye's Avatar
Car: 1986 Trans Am
You're best bet is go to pepboys, and go to the chevy section and look for the "torque convertor nuts and bolts" that I mentioned, and take notice to the size, length and thread of it's contents, and then walk over to the bolt section and buy the same bolts as what's in the package, it'll save you $3-$4.
Old Dec 17, 2003 | 08:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
DONT FORGET THE LOCKTITE!
Old Dec 17, 2003 | 11:32 AM
Stingraye's Avatar
Car: 1986 Trans Am
Yeah that too.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
