Throwout bearing fell off fork?!?
Car: '82 Z28
Engine: 350HO
Transmission: M4
just for background. I have a 1982 Z28 with a saginaw four speed, and mechanical clutch linkage.
Well, i was driving home from work today, as i was getting ready to turn a corner and downshift into second, when i went to push the clutch pedal in, there was nothing there...
so between shifting without the clutch, and starting the car in gear(at lights) i was able to drive the car home and park it.
so i jacked it up, figring that it was just a clutch linkage problem, being that i have mechanical clutch linkage
nope the linkage is fine, and pushing in the clutch pedal results in full throw of the linkage. and the clutch fork feels extremly loose, you can wiggle it back and forth, and push it in about an inch or so. i've never been able to push the fork in ( too much pressure from the pressure plate fingers).
so my best guess is that the throwout bearing fell of the clutch fork ?!?.
when you push pedal in, the farther you get to the floor, you feel a little tiny bit of resistance, but not the kind of resistance a proper clutch gives.
and i figure that the clutch and pressure plate are fine, because i was able to get home just fine, power is still able to get to the wheels.
now before RB posts the pictures of whether or not i installed the throwout bearing correctly, it was.
i just put a new engine in the car about 3-4 months ago, and when i did that, i installed a new clutch, pressure plate, pilot bearing, and throwout bearing as well. and everything has worked properly since then.
so i know i need to drop the tranny for about the 3rd time in 6 months (which im not looking forward to doing)
but my best question is, if the throwout bearing fell off the fork, does that happen often? because it sounds like the man upstairs just hates me
Car: '82 Z28
Engine: 350HO
Transmission: M4
i just went and took a look at it, thats exactly what happend..
how do i go about getting it back on, without removing the transmission?
Car: '82 Z28
Engine: 350HO
Transmission: M4
after i thought about it, doesn't the pilot stud have clips to hold the clutch fork on?
so that clip would have had to break for the fork to slip off right?
so im going to have to dtop the trany anyway huh?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Pete
mygta87
Sep 14, 2015 10:36 PM
